Private Lan2 on virtual DCE
  • Private Lan2 on virtual DCE
126
65
Posted: ‎2020-08-14 02:25 PM
1248
Hello DCIM support team,
A new DCE virtual machine was created with 2 network adapters but it is not visible in the network settings screen.
When I tried to enable the private adapter in the console an error message appears.
What else I may to do to get the LAN2 (private) to show up?
thanks a lot for your support
Regards
Luis Lopez // SE FSR from CR
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2020-08-15 07:48 PM
"...other host 78:2B:CB:0D:55:4C already uses address 192.168.1.1". Maybe you want to remove this host (78:2B:CB:0D:55:4C) or change the IP address for this host to avoid IP conflict. DCE Private LAN uses 192.168.1.1 by default.
BR,
TJ
tjlaw
Lt. Commander
BR,
TJ
