PowerChute Network Shutdown for Linux: regenerate SSL Certificate?
  • PowerChute Network Shutdown for Linux: regenerate SSL Certificate?
129
72
Posted: ‎2020-07-03 12:51 PM . Last Modified: ‎2024-04-08 01:48 AM
1539
Hi all!
I looked for information how it is correct to execute regeneration of self-signed SSL certificate in PowerChute Network Shutdown for Linux in case of, for example, change of hostname or other sensitive information about the server. Unfortunately found only information how to use a certificate, that has been signed by a Trusted CA instead of the self-signed certificate, no more. For example, FA176886 and PowerChute Network Shutdown v4.2 FAQ.
As in practice in my case everything was very simple 😀. For this purpose just it is necessary to stop the PowerChute service on the server, then to delete two old keystore and PowerChute-keystore files and again to start the PowerChute service.
For example in RHEL/CentOS-6.x:
bashMidnightPCNS in RHEL/CentOS-6.x# service PowerChute stop # cd /opt/APC/PowerChute/group1 # rm keystore PowerChute-keystore # service PowerChute start
For examle in RHEL/CentOS-7.x:
bashMidnightPCNS in RHEL/CentOS-7.x# systemctl stop PowerChute # cd /opt/APC/PowerChute/group1 # rm keystore PowerChute-keystore # systemctl start PowerChute
After successful start of the PowerChute service new self-signed SSL certificate already with updated information about a host will be again created, as it was required in our case. That's it.
Very thanks for the support.
(CID:111414736)
  • DDF
This question would be better suited on http://forums.apc.com.
 Perhaps, but I think and here for community will interestingly know, that starting with the DCE-7.4.1 is realized support for servers with the installed PCNS-4.2 software (by default in DCE present the appropriate DDF-file). Of course under a condition if PCNS-4.2 was setup with the enabled SNMP. And if it so, then in DCE-7.4.1 and above we see here such "Device Alarm Configurations" for the server with PCNS-4.2:
Concerning the Warning "PowerChute Software Update Available": this warning will be active under a condition, if in the PCNS-4.2 settings the "Send SNMP Trap when Update is available" function is enabled:
Besides, in the PCNS-4.2 SNMP settings it is necessary to specify as the trap receiver the target server DCE-7.4.1 and above:
P.S.: for successful "Check for Updates" of the PCNS, at the server, where this program is installed there shall be an outgoing access to production update URL: https://updates.apc.com:443/
(CID:111414982)
Spezialist,
Cory
(CID:111414758)
(CID:111414982)
Posted: ‎2020-07-03 12:52 PM . Last Modified: ‎2023-10-22 03:37 AM
