Possibility of integration DCO and SCOM 2016 R2?
  • Possibility of integration DCO and SCOM 2016 R2?
129
72
Posted: ‎2020-07-05 10:27 PM . Last Modified: ‎2024-04-03 12:28 AM
951
Could you please clarify for me question of out-of-box integration of DCO and SCOM 2016 R2. Based on information from manual - it's impossible. Is it right?
Pavel
(CID:149292853)
  • Data Center Operation
Replies 5
951
Hi Pavel,
If you are referring to integrating with Virtual Machine Manager through StruxureWare Data Center Operation: PRO Pack (https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/StruxureWare+Data+Center+Operation%3A+PRO+Pa...) , then yes, that should be possible in DCO 8.x.
Kind regards
(CID:149292864)
Thank you Jef. I see possibility of SCOM integration, but my question is about exact SCOM 2016 R2 version.
(CID:149292989)
Hi Pavel,
We haven't tested that, so I cannot offer a clear answer about the exact version. Do you see issue with integration? If the integration/communication is through http, then make sure the "Redirect HTTP to HTTPS" is not enabled in DCO.
Kind regards
(CID:149292991)
Thank you, Jef.
I'll try.
Pavel
(CID:149293029)
Posted: ‎2020-07-05 10:27 PM . Last Modified: ‎2023-10-22 03:35 AM
