Portlet DCO Capacity Overview remains waiting
  • Portlet DCO Capacity Overview remains waiting
127
65
Posted: ‎2020-07-03 07:34 AM . Last Modified: ‎2024-04-08 04:08 AM
761
I've installed struxtureWare Portal 1.3.4 and I've connect it DCO 7.5, when I add portlet "Capacity Overview" I can't see the output becouse the portlet is wait.
If I add other type of portlet DCO (also DCE) it work properly. This is a strange problem and I don't find solution.
(CID:110004067)
  • Portal
Posted: ‎2020-07-03 07:35 AM . Last Modified: ‎2024-04-08 04:08 AM
762
Unfortunately, StruxureWare Portal v1.3.4 is not backward compatible with DCO7.5.
(CID:110004080)
Replies 4
I have exactly the same problem, I have tried to reconfigure the setting for the portlet with no luck, so would also like to know how to fix this problem.
(CID:110004081)
763
(CID:110004080)
This also doesnt work with 8.0.1
(CID:110004089)
Posted: ‎2020-07-03 07:35 AM . Last Modified: ‎2023-10-22 03:35 AM
