Portal v1.3.3 on Debian
  • Portal v1.3.3 on Debian
127
Posted: ‎2020-07-03 04:40 AM . Last Modified: ‎2024-04-08 11:35 PM
731
I recently installed DCO portal 1.3.3 on Debian for demo purpose. I wanted to share some tips specifically related to Debian
  1. Please make sure you use the command of chmod to change the right of install.sh right after you unzip the file
  2. You must add "sudo" to execute the install.sh (sudo bash install.sh installPostgres noupgrade start)
  3. After executing install.sh, you need to go to the Debian user account administration console. There you will see a new account created - liferay. It is at disabled statue. Please unlock the account and enable the liferay account by setting password for it. (The password policy is strict for Debian. Your password must contain upper case alphabet and use uncommon combinations to fulfill its requirements). Please also allow liferay user account to automatically login upon boot
  4. In case you need to start portal service manually, you need to execute startup.sh, which is located at the folder /opt/StruxurewarePortal/liferay/tomcat/bin
Wish you all the success in using Debian~
(CID:106891358)
  • Data Center Operation
  • Portal
  • linux
Posted: ‎2020-07-03 04:40 AM . Last Modified: ‎2023-10-31 11:29 PM
