Portal location map portlet doesn't show the linked lines
  • Portal location map portlet doesn't show the linked lines
127
65
Posted: ‎2020-07-03 01:10 AM . Last Modified: ‎2024-04-09 12:42 AM
945
Hello guys,
When I add markers into a location map portlet, doesn't show the lines from the marker to the map.
Best regards,
Enric
(CID:105468700)
  • Portal
Replies 4
945
Hi Enric,
It might be basically a configuration issue, ie. after adding the Marker, you need to select and drop a "portlet" and configure it.
Kind regards
(CID:105468897)
Posted: ‎2020-07-03 01:10 AM . Last Modified: ‎2024-04-09 12:41 AM
Hi Jef,
As you can see in the attached screenshot, I've dropped a porlets in all markers, but I only can see one linked line (in this example the Moscu linked line).
Enric
(CID:105470141)
Hi Enric,
It seems the other lines are behind the corresponding markers (arrow 1 in my illustration) -  to point the lines to other location:
- log in to Portal,
- go to Location Map
- move the marker (arrow 2) slightly until the line is "out"
- and then move the line (arrow 1) to point to correct location
(location of the markers and lines can be adjusted/managed by moving those small circles, (arrow 1 and 2))
Kind regards
(CID:105470183)
Posted: ‎2020-07-03 01:10 AM . Last Modified: ‎2023-10-31 11:29 PM
