Posted: 2020-07-04 03:18 PM . Last Modified: 2024-04-05 12:39 AM
Hi guys,
since the latest upgrade of the portal server the connection to the DCE mobile page is no longer possible due to certificate errors.
Does anybody have a hint on how to solve this issue within the iframe?
(CID:129406844)
Hi Lukas Jegerlehner, thanks for posting. Let's hope you find your answer here.
Kind regards Ditte
(CID:129410875)
Posted: 2020-07-04 03:19 PM . Last Modified: 2024-04-05 12:39 AM
Hi Lukas,
I have also run few tests using the latest versions of the products (Portal, DCE & DCO) & browsers, and it seems due to security reasons IFrame is actively blocked. Browsers such Chrome may notify that "We should block requests for subresources that contain embedded credentials (https://www.chromestatus.com/feature/5669008342777856).
Kind regards
(CID:131964952)
Posted: 2020-07-04 03:19 PM . Last Modified: 2023-10-22 03:34 AM
