PCNS-4.2 and SxW DCE 7.4.3: device "model" is not detected (type OS)?
Showing results forΒ
Did you mean:Β
  • PCNS-4.2 and SxW DCE 7.4.3: device "model" is not detected (type OS)?
129
72
Posted: β€Ž2020-07-03 05:52 PM . Last Modified: β€Ž2024-04-08 12:03 AM
1539
Hi all!
I found a bug, most likely, in PCNS-4.2.
Essence: after discovering a server or workstation running PCNS-4.2 with the enabled SNMP service, the SxW DCE-7.4.3 does not detect the device "model" (for example, the OS server type, etc.).
Very thanks for the support.
(CID:122689826)
  • DDF
  • bug
Hi all!
I am pleased to confirm, that in the new version of DCE-7.5.0 the above bug has been successfully fixed:
The problem was solved by corresponding modification of the pcns.xml v.5 DDF-file.
Thanks for good job πŸ˜€.
(CID:128757126)
Replies 8
1539
Hi Spezialist,
What OS are you running? I discovered a 4.2 PCNS install and I see basic OS info:
You're also mentioning "model". If you're looking for the UPS model, that's not something you get from PCNS, you'd have to get that from the UPS' NMC directly.
Steve
(CID:122689860)
Hi Steven Marchetti,
Of course, the sensor "OS" works correctly, but I did not write about it. I wrote about the "Model" field, which is displayed in the "Device View" window of the table of all devices in the DCE-client.
(CID:122689873)
Again, PCNS doesn't report the UPS  which would be the device model. I didn't see that this was being specified but if you're asking that PCNS 4.2 be shown under model, we are pulling 4.2.0:
.1.3.6.1.4.1.318.1.2.3.1.2.0
and perhaps the DDF team could make an enhancement to the DDF if there's no reason not to do so and turn that into a model.
Steve
(CID:122689887)
I think, that when a new SNMP device is discovered, the DCE-server first reads the value of sysObjectID.0 (.1.3.6.1.2.1.1.2.0). Knowing this value, the DCE-server on its internal database sysObjectIDs determines what kind of model the device is. For example, this happens when you discovered a server or workstation in DCE.
If we have a server/workstation with PCNS-4.2 installed, then its sysObjectID.0 = .1.3.6.1.4.1.318.1.3.31.1. And probably, DCE-server, not having found in itself in a database sysObjectIDs of the description of model for the given value, leaves the field "Model" empty.
Well, Steven Marchetti for my example, what "Model" should it be in DCE: OS Linux/Windows or PCNS version or model of UPS (to which this server/workstation is connected)?
(CID:122689898)
Spezialist,
It's not in a database, it should actually poll the device / software again looking for:
.iso.org.dod.internet.private.enterprises.apc.products.system.pcns.pcns4
When polling the client, that OID returns nothing. I can inform the PCNS folks but I don't work directly with that product.
Steve
(CID:122689916)
It's not in a database, it should actually poll the device / software again looking for: .iso.org.dod.internet.private.enterprises.apc.products.system.pcns.pcns4
Of course I wrote "database", meaning not a real database πŸ˜€, but only some way of searching by sysObjectID.0 for the correct combination of vendor/model/type of SNMP device.
I'm glad that you understood the essence of my question. I will be grateful to you for this.
(CID:122689995)
Hi all!
(CID:128757126)
Posted: β€Ž2020-07-03 05:52 PM . Last Modified: β€Ž2023-10-22 03:29 AM
