Posted: 2021-12-03 02:31 AM
I need to connect cables between floors. But We created all flats as a New Server Room. So I need to connect network cables between two server rooms. How can we do this. ı couldn't see the other server room when ı connect cables.
Best Regards;
Barlas
Posted: 2021-12-03 03:01 AM . Last Modified: 2021-12-03 03:53 AM
Hi Barlas,
To make a network connection between two patch panels located in two different rooms, try as illustrated:
In patch panels properties > Network, select a configured port (1) , click Connect to... (2) , select room (3) and continue the configuration.
Kind regards,
Hi Barlas,
Kind regards,
