Netbotz 750 firmware update using CLI
  • Netbotz 750 firmware update using CLI
126
65
Hogg
Ensign Hogg
Ensign
Posted: ‎2025-04-15 06:22 AM
1030
Hello all,
Is there a way to upload and kick off a firmware update using the CLI?
I have a Netbotz 750 on firmware version 5.2.1.150.
When I try to update it to 5.3.5 it takes a very long time but never completes.
I was hoping this is a GUI issue and I could upload and install over SSH.
Thanks in advance for any help.
  • NetBotz
Captain
Posted: ‎2025-04-16 04:28 AM
995
Hi @Hogg ,
Sorry, but even in newer firmware, this option is not yet available. I would suggest contacting your local support team. If the file never gets fully uploaded to the device, there is a way to get around that but the actual update must be initiated through the web UI.
Steve
Replies 4
Captain
996
Hi @Hogg ,
Steve
Hogg
Ensign Hogg
Ensign
Posted: ‎2025-04-17 01:30 AM
Thank you!
TimGRAFM
TimGRAFM
Cadet
Posted: ‎2025-06-11 05:59 AM
In response to APC_Steve
Hi, I also have a Netbotz 750 on 5.3.5.434. The latest version (PROD_SIGNED_NBRK075x_Build_5.4.0.11) doesn't really upload at all - I get a small initial amount of bar but it stops. The Ecostruxture console reports that it is frequently offline and I am under pressure to solve this problem.
So if there's another solution I would love to know it.
Captain
Posted: ‎2025-06-13 04:05 AM
Hi @TimGRAFM ,
I would say the same as before. If the file never uploads to the device, support may be able to assist. If it's frequently offline, that could be a different issue. It could be a network issue in which case, I would suggest trying a crossover cable from laptop to NetBotz. It could be an issue with the NetBotz itself where again, I suggest contacting your local support.
Steve
