Netbotz 250 is showing Err on Beacon, Relay Output, Switched Outlet
  • Netbotz 250 is showing Err on Beacon, Relay Output, Switched Outlet
126
65
EcoStruxure™ Power Advisor
Akansha
Akansha Cadet
Cadet
Posted: ‎2024-01-05 09:29 AM
1280
I was trying to connect 3nos. Temperature/Humidity sensor with display (AP9520TH) via Netbotz 250 A link port. After reset netbotz is shoiwng Err on Beacon, Relay Output, Switched Outlet. 
Now Netbotz is not detecting any TH sensor. Kindly suggest.
  • DCIM Support
JohnBT
Lieutenant JG JohnBT Lieutenant JG
Lieutenant JG
Posted: ‎2024-01-08 03:55 PM
1240
If you have done a reset to default, last thing to try is do a format.  Login to telnet or SSH then run the format command.  If the issue is still there, then its most likely a hardware issue.
You can contact your local CCC and provide the same information you shared here and the logs from the Netbotz 250.  Your local CCC will be able to check if the device is still under warranty.
JohnBT
Lieutenant JG
1241
Akansha
Akansha Cadet
Cadet
Posted: ‎2024-01-09 01:25 AM
In response to JohnBT
1225
After format still same issue of Err and unable to add any sensor in netbotz 250.
Firmware version is also latest.
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2024-01-14 05:51 AM
In response to Akansha
Have you tried to disconnect all sensors, the A-Link device, then perform a reboot? See if the status is still showing "err"?
If the status is restored to normal, try plugging in the sensors individually, and A-Link with the terminator.
BR,
TJ
