Netbotz 250 Advanced view
  • Netbotz 250 Advanced view
129
72
Posted: ‎2020-07-03 02:38 PM . Last Modified: ‎2024-04-08 01:15 AM
2373
Hello
I would like to ask if exist any way to use Advanced view to monitor netbotz 250
When i tried to connect to netbotz from Advanced view (4.5.4) it always opens in IE, not in application
(CID:116361863)
  • Data Center Operation
  • Bonjour
  • bug
  • The Application Not Able to Load
Posted: ‎2020-07-03 02:38 PM . Last Modified: ‎2024-04-08 01:14 AM
Hi Michal,
No, the technologies of the NetBotz 200 and 250 differs from that of the 3xx, 4xx, and 5xx series NetBotz devices. The 200 and 250 are based on the same technology of the APC network management card while the 3xx, 4xx, and 5xx are based on the different NetBotz technology. Advanced View only supports that original NetBotz technology and the 250 must be configured through it's web interface.
Steve
(CID:116361872)
Replies 5
Michal,
There is no way to monitor a 250 using Advanced View.  It can only be accessed via the web GUI
(CID:116361868)
Hi Michal,
Steve
(CID:116361872)
Rack Monitor 250 is only accessible through web page you can't access through advance view application.
(CID:116361877)
no buddy its not possible i already tried on it . but its not working .
(CID:116362640)
Posted: ‎2020-07-03 02:39 PM . Last Modified: ‎2023-10-22 03:16 AM
