Posted: 2020-07-02 05:13 PM . Last Modified: 2024-04-09 02:32 AM
Hi team,
Just want to confirm with you if NTP is not supported by DCO.. The DCE and DCO are installed at the site. How can we sync the time on the 2 servers? We can enable NTP feature on the DCE, but it seems NTP is not supported by DCO..
(CID:104173634)
Hi Annie,
Through Webmin console of DCO, there is the section of "Setup" under StruxureWare Data Center Operation.
It may take a while to show up all the setting section, but shows up like this.
best regards,
Yoshi
(CID:104173639)
Posted: 2020-07-02 05:14 PM . Last Modified: 2024-04-09 02:32 AM
Found it. Thanks! it is "setup" under DCO
(CID:104173647)
Hi Yoshinobu, I have a problem while sync ntp server with DCO server as you can see at attached. Did you see any error like that or do you know where is the problem? I integrated before that NTP server with DCE. Thanks Kerem
(CID:105462544)
Posted: 2020-07-02 05:14 PM . Last Modified: 2023-10-31 11:27 PM
