Posted: 2020-07-05 06:16 PM . Last Modified: 2024-04-03 03:03 AM
God day
How I can change the security level for my backup in the DCE 7.2.7 to NTLMv2 in the console
(CID:141266174)
OMAR ALFREDO CUERVO DONCEL ,
Video: Data Center Expert | Backing up to a Windows Share
https://www.apc.com/us/en/faqs/FA299440/
Excerpt from the knowledge base:
NTLM version 2 Support
StruxureWare Data Center Expert versions before 7.3.1 do not support mounting to shares that require NTLMv2 authentication. In some situations, it may allow you to successfully “test mount”, but will not authenticate when attempting a backup or when using this share as a remote repository. It is recommended to use a share that allows for NTLMv1 authentication and to contact technical support to have your software support verified and receive upgrade links.
Kind Regards,
Cory
(CID:141266183)
Dear OMAR ALFREDO CUERVO DONCEL ,
Tell us, please, did you solve your question or not?
With respect.
(CID:141269178)
Posted: 2020-07-05 06:16 PM . Last Modified: 2023-10-22 03:09 AM
