Multiple tower workstations on Tiered Shelving
  • Multiple tower workstations on Tiered Shelving
129
72
rcrowe
rcrowe
Cadet
Posted: ‎2022-02-23 06:47 PM
972
Is there a way to create wide multi tiered shelving within ITA that will support multiple tower type workstations?
I can use a 4 post rack and shelving but when I make it wider, I can still only use the original 19" opening to place workstations onto the shelf
thanks
Richard
  • Data Center Operation
  • IT Advisor
Captain
Posted: ‎2022-02-24 03:59 AM
ITA does support shelving and the ability to place items on the shelves, even stack small items like modems, mac mini's and so on on shelves.
It seems however even when I widen the rack as I did below the inside as you mentioned does remain limited to 19in wide. I will file an engineering ticket to request the ability to adapt or specify the rack mounting width.
As a workaround, I'd suggest editing the above rack mount devices to make them slightly slimmer so they could be set side by side.
Regards
Greg Sterling
Captain
Regards
Greg Sterling
