Posted: 2020-07-04 02:48 AM . Last Modified: 2024-04-05 03:43 AM
hello,
I see some strange problems. Directly in the pm5560 webpage you can see all of the Inputs are "on" but in DCE the DI 4 shows "off"
What could be this problem and how can I create alarms if one of these Digital Inputs switches in state?
Thank you
(CID:126186161)
Posted: 2020-07-04 02:48 AM . Last Modified: 2024-04-05 03:42 AM
Hello
First, you have to check the modbus reghisters value for that DI.
I prefer to use this command line utility from http://www.modbusdriver.com/modpoll.htm for diagnostics...
Once it became clear if DI4 is really on or off then it will be more clear there the reason of your issue is 😀
(CID:126880767)
Posted: 2020-07-04 02:48 AM . Last Modified: 2023-10-22 03:04 AM
