Metered Rack PDU: Internal power supply #1 fault
  • Metered Rack PDU: Internal power supply #1 fault
127
65
Posted: ‎2020-07-05 01:20 PM . Last Modified: ‎2024-04-04 12:34 AM
3956
Hi Team,
This was first time i have seen this alert from a PDU. Kindly let us know why this is causing it and solution for it.
(CID:134688429)
3950
This is one of the more common failure modes for the Rack PDU's.  The PDU is faulty and needs replacement if you want to remove the fault.
Eventually the secondary supply will fail and you will lose monitoring capabilities on the PDU.
Regards
(CID:134688437)
3951
Regards
(CID:134688437)
Thanks for your quick reply
(CID:134688483)
Posted: ‎2020-07-05 01:20 PM . Last Modified: ‎2023-10-22 03:02 AM
