McAfee Vulnerability Error StruxureWare Portal
  • McAfee Vulnerability Error StruxureWare Portal
126
65
Posted: ‎2020-07-04 07:54 PM . Last Modified: ‎2024-04-04 11:04 PM
877
Good day
Please assist
Our StruxureWare Portal server has been identified as a Security risk to the business. See below Vulnerability errors from our Security Team:
TLS/SSL RC4 Cipher Suites Information Disclosure Vulnerability [FID 18179]
SSL/TLS Protocol Triple-DES Information Disclosure Vulnerability [FID 20465]
SSLv3 Information Disclosure Vulnerability [FID 17281]
Web Server Supports Outdated SSLv2 Protocol [FID 1858]
With the exception of error "  Web Server Supports Outdated SSLv2 Protocol [FID 1858]"  McAfee recommends to disable the TLS/SSL protocol.
Please advise what is the impact should we proceed to disable these protocols.
Portal version - 1.3.5
Kind regards
Juice
(CID:132661575)
  • Portal
Replies 4
875
Hi Juice,
I was wondering perhaps restricting the ssl protocol to TLS 1.2 (sslProtocol="TLSv1.2") could be an option to try out. Following page describes how to enable/configure ssl in Portal: Enable SSL in StruxureWare Portal
However Portal is based on Liferay 6 (currently no plans for update) so I won't be surprised if it doesn't pass the vulnerability scans.
Kind regards
(CID:132662634)
Thank you Jeff... very much appreciated.
I wil have to raise this at our change management.
Once again thank you for your assistance
kind regards
(CID:132663515)
You are most welcome, Juice
Kind regards
(CID:132663517)
Posted: ‎2020-07-04 07:54 PM . Last Modified: ‎2023-10-22 03:01 AM
