Is there a way to have cooling (CFD) be truly dynamic in DCO ?
  • Is there a way to have cooling (CFD) be truly dynamic in DCO ?
129
112
72
Posted: ‎2020-07-04 08:57 PM . Last Modified: ‎2024-04-04 04:00 AM
759
I have no end of trouble getting DCO to show a reasonable representation of reality with regards to cooling.
It seems as if the whole system relies upon staticly configured manual entries.
ie: cabinet is presumed to pass X cfm per kW
However, I have cabinets with exhaust fans in the chimneys - and the fans are metered, and in the system  -  DCO should use the real time data
Additionally - I have set the CFM of my  CRAC units - I would expect the system to understand that the CRAC units CFM should equal the discharge from your supply tiles , perhaps minus some percentage for leakage... but that doesn't seem to be the case,
In my case - the presumption of the cabinets air flow is massively imbalanced compared to the CRAC units known air flow -
am I just missing some switch that says - "make this work like reality" or something ?
(CID:132669922)
  • Data Center Operation
Posted: ‎2020-07-04 08:58 PM . Last Modified: ‎2024-04-04 04:00 AM
Hi Eric,
I would try using/associating some temperature sensors, and then running the 3D view based on "Measured plane":
that may provide us more realistic simulation of the temperature map.
Kind regards
(CID:133370561)
Posted: ‎2020-07-04 08:58 PM . Last Modified: ‎2023-10-22 02:50 AM
