Posted: 2020-07-05 09:04 PM . Last Modified: 2024-04-03 01:00 AM
I am trying to get a list of devices in StruxureWare Data Center Expert that use SNMPv1 protocol. I can see this in the Device Scan Settings but can not figure out a way to export that list into another format such as a CSV file. Is there a way to do this or is there another way to get this list?
(CID:147199654)
Posted: 2020-07-05 09:04 PM . Last Modified: 2024-04-03 12:59 AM
Hi Eddie,
Sorry, no, you can not export the device scan settings. If you've discovered the devices using unique device discoveries, maybe exporting the discoveries will help. If the ranges overlap however, I'm not sure if it'll help. The export will look something like this:
SNMPv1:10.10.10.131-155:161:2:3:true:public:private
SNMPv1:10.10.10.56:161:2:3:true:public:private
This will apparently only show SNMP v1 discoveries though.
Steve
(CID:147199665)
Thanks Steve. I had a feeling that was the case.
(CID:147199702)
Posted: 2020-07-05 09:04 PM . Last Modified: 2023-10-22 02:50 AM
