Is it necessary to model the "Row" object?
  • EcoStruxure IT forum
  • Is it necessary to model the "Row" object?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:33 AM . Last Modified: ‎2024-04-08 11:56 PM
694
As most users know, reading the network or power path routes can be a challenge... especially when a good naming convention has not been put in place. If we were to NOT model the row objects within our cages... does that break any simulations that possibly rely on that object?
Is it safe to eliminate this from our rooms... thus reducing the length of the paths? Making it a little easier? Or is this just a preference when it comes to organizing the Navigation pane?
(CID:106206553)
  • Data Center Operation
Hi Wes,
As you've mentioned using the row objects will make the organizing and navigation pane more tidy (specially navigation pane will display the items in a well organized order).
However, it is not necessary to model the "Row" object. I believe it is also safe to eliminate this from the setup - but before removing from all rooms it would be good idea to test it on one room first.
Note: as usual it is recommended to take a fresh backup before doing any major changes.
Kind regards
(CID:106206712)
Hi Wes,
Kind regards
(CID:106206712)
Posted: ‎2020-07-03 03:33 AM . Last Modified: ‎2023-10-31 11:11 PM
This is a heading
