Is it Applicable to change the ETL Database Port no. (5432) ?
  • Is it Applicable to change the ETL Database Port no. (5432) ?
126
65
aashraf
Lieutenant JG aashraf Lieutenant JG
Lieutenant JG
Posted: ‎2020-09-08 02:32 AM
1709
Dear Gents,
Is it Applicable to change the ETL Database Port no. (5432) to be any thing else ?
Ahmed Ashraf
  • Data Center Operation
  • DCIM Support
Admiral
Posted: ‎2020-09-10 12:02 AM
In response to aashraf
Hi Ahmed,
That's correct, the communication port for the internal/local database cannot be changed.
Kind regards,
Admiral
Posted: ‎2020-09-08 06:22 AM
2
1695
Hi Ahmed,
As described in the following page:
https://helpcenter.ecostruxureit.com/hc/en-us/articles/360012046197-ITA-network-firewall-port-detail...
port 5432 is used by server (DCO/ITA) to communicate with its own database - this cannot be changed.
however, for the ETL integration with external systems/database the port (default 5432) should match postgres settings to allow ITA/DCO to connect to the database server, so if the database server (external system) is configured and listening on another port, then that port should be set up in ETL settings.
Kind regards,
aashraf
Lieutenant JG
Posted: ‎2020-09-09 06:08 PM
In response to Jef
1675
Hi Jef,
Also for ETL integration with internal database the default port is 5432 and cannot be changed, Is that correct ?
Ahmed Ashraf
Admiral
Hi Ahmed,
Kind regards,
