Integration between two DCE Systems
  • EcoStruxure IT forum
  • Integration between two DCE Systems
125
65
Back to EcoStruxure IT forum
aneta.deliu
Crewman aneta.deliu
Crewman
Posted: ‎2024-08-16 06:08 AM
591
I am interested to know if there is possibility to gather data from one DCE system to another DCE system via SNMP.
There is 1 DCE system in site A and another DCE system in site B. I need all the information from both sites to view in site A from DCE. 1. Is this possible? 2. Via SNMP? 3. And how?
What I have tested up to know is to monitor data of VM in site B (like link status, CPU etc. of the VM) from DCE in site A.
Thank you in advanced.
  • DCIM Support
Admiral
Posted: ‎2024-08-20 06:37 AM
Hello @aneta.deliu,
Data Center Expert does not have any data import mechanisms to import device/sensor data to "combine" DCE servers into a single pane of glass.  You are correct that if you discover a DCE appliance in another DCE or monitoring tool that you will only get data on the server, not the device discovered on that server.
Depending on your licensing and site size, you may be able to monitor all devices from a single DCE server instead of having 2 DCE appliances doing the monitoring.  This is not always a viable solution depending on your security requirements and existing solutions.
You can also reach out to sales to discuss EcoStruxure IT Expert  which would give you a single pane of glass to view sensors data via the cloud, including a mobile app.  There are differences with this solution that you can investigate further on https://se.com/dcim
Kind Regards,
Cory
Admiral
Hello @aneta.deliu,
Kind Regards,
Cory
