Posted: 2020-07-05 07:31 PM . Last Modified: 2024-04-03 02:37 AM
I need to install 12 AP9520TH, through 01 NBRK0250
Could you please tell me if that is feasible?
If so, what accessories are required for this?
(CID:143760544)
Hi Javier,
Good day!
The maximum number of AP9520TH that can be added to the Netbotz 250 is eight (8).
These sensors are cascaded using Cat5 cables through the A-link ports with terminators on both ends of the line (A-link IN of the Netbotz 250 and A-link out of the 8th AP9520TH) to avoid communication loss.
To know more about this, please refer to page 10 of the Netbotz Rack Monitor 250 Installation and Configuration Guide from the Documentation section of this website.
I hope this helps.
Justine
(CID:143760730)
Hi Javier,
Good day!
I hope this helps.
Justine
(CID:143760730)
Thanks Justine
(CID:144310769)
You're welcome
(CID:144310857)
Posted: 2020-07-05 07:32 PM . Last Modified: 2023-10-22 02:46 AM
