Posted: 2020-07-05 06:58 PM . Last Modified: 2024-04-03 02:48 AM
Hello
I'm going to install DCO 8.2.7 on Linux RedHat 7.5(min install)
According to the following link I didn’t find the Linux lib .
Can you send me link to lib prerequisite before installation
(CID:143264741)
Hi Boris,
Please see the following page:
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Installing+DCO+on+Red+Hat+Enterprise+Linux+7
and by way, the latest DCO release is 8.3.
Kind regards
(CID:143264775)
Hi Boris,
Kind regards
(CID:143264775)
Hi Boris,
I think in general Linux libs usually modified/updated so it is not practical (from DCO development point of view) being documented. You might want to try with RHEL server (probably not with minimum install but a "full" server install) with access to RHEL packages (preferably by using an active RHEL subscription). Then during dco installation (as application), installer should be able to download and install what ever is needed.
Kind regards
(CID:143754969)
Hello Jef
Many thanks . This link I did see and know.
My question regarding the the Linux libs that I need to install before run the DCO installation
(CID:143755876)
Posted: 2020-07-05 06:58 PM . Last Modified: 2023-10-22 02:45 AM
