Incorrect measured values, ION 7650
  • EcoStruxure IT forum
  • Incorrect measured values, ION 7650
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:10 PM . Last Modified: ‎2024-04-05 12:18 AM
1068
Hi, I have Incorrect measured values, the meter is not connected to TC's or something else but in the DCE client displays high measured values.
best regards!
(CID:130091967)
  • DDF
Replies 6
1068
Dear Ernesto González,
Perhaps you have an incorrect version of the Modbus DDF-file for your ION7650. Tell us please, what is your version of DCE software and what is the version of the Modbus DDF-file for PowerLogic ION 7650? For example, I have the latest DCE-7.5 software and the version powerlogic_ion7650.xml is v.2.
In addition, on the Device Support resource you can also find the ION7650 device as on my screenshot:
Try to press the button I WANT IT TOO and within one or two business days you will be sent a web-link to download the corresponding DDF-file. Import it into your DCE software and try. Maybe this will lead to a positive result.
If, however, you do not succeed, then you need to click on the Request modification web-link as in the screenshot above. As a result, you will make a modification request, i.e. to modify the DDF-file to ensure, that the readings of the sensors in the DCE software are correct.
I hope this helps you 😀.
With respect.
(CID:130092083)
Hi, I have the version 2, does exist a new version?
(CID:130094804)
Posted: ‎2020-07-04 04:11 PM . Last Modified: ‎2024-04-05 12:18 AM
As soon as I have more information, I'll let you know.
With respect.
(CID:130094884)
1068
Hi Ernesto,
It looks like the raw values being returned by your ION7650 are all value 0xFFFF, which is showing up as 65535 for unsigned values and -1 for signed values, scaled as appropriate to the sensor.
It's common for Modbus devices to use the value -1 as a "Not Available" flag.
You should check to make sure your ION7650 is properly configured.
Glenn Martin
(CID:130092301)
Hi Martin.
could you help me with the configuration, I’ve download the configuration meter.
config.txt
Regards.
(CID:130094918)
Posted: ‎2020-07-04 04:11 PM . Last Modified: ‎2023-10-22 02:43 AM
