Include info in custom column into email
  • Include info in custom column into email
126
65
Posted: ‎2020-07-03 05:08 PM . Last Modified: ‎2024-04-08 12:18 AM
1111
I created a custom column "Slave Location" for MODBUS device to identify slave device location. The question is how can the email pick up the Slave Location?
(CID:120134841)
Replies 8
1111
Hi Yang Gao,
Unfortunately, this is not provided.
A complete and up-to-date list of macros, that you can use in email alerts can be viewed on Macros for alert action settings page and in the pdf-manual User Assistance for StruxureWare Data Center Expert 7.4.x, starting on page 182.
Therefore, you can create an appropriate Feature requests according to your wishes, and hope that in future releases of DCE this will be implemented.
With respect.
(CID:120134865)
 The following email is sent from DCE for a circuit breaker which is MODBUS slave device. It is very hard for user to understand what this device is and where it is located. Do you have any suggestion to make this email alert more clear for user to understand?
Alert   Title:
OF   Status - value alert resolved
Alert   Description:
The value of 'OF Status' had indicated that a 'Critical' alert had   occurred, but has returned to normal.
Alert   Type:
Value   Error
Severity:
Critical   (returned to normal)
Alert   Level:
Return   To Normal
Sensor:
OF   Status
Sensor   Value:
Closed
Device:
10.192.45.42   - Slave 47
Time   Detected:
06/13/17   05:38:54
Time   Returned to Normal:
06/13/17   05:39:53
Notification   Time:
06/13/17   05:45:14
Action   Name:
Email   to EPS6000 UPS LCM
Alert   ID:
nbErrorCond_FEA278A1
Version:
7.4.3.26
(CID:120134933)
The Macros for alert action settings could use some love.
(CID:120135019)
1112
I understand you perfectly, because I myself often deal with this.
Therefore, I highly recommend to abandon the usual HTML-based email and use ASCII-based email, in which you can use the above macros. Thus, you can very flexibly and briefly compose the contents of these messages so that users understand them without difficulty. Well about this is written, for example, in the topic .
I am glad to answer your questions.
(CID:120134945)
Posted: ‎2020-07-03 05:09 PM . Last Modified: ‎2024-04-08 12:18 AM
Using ASCII-based email and macros will not fix my problem. There is no corresponding macro for a user defined column such as my "Slave Location".
How does DCE get the Location from a MODBUS slave device? Is there a common register for all MODBUS devices?
(CID:120134975)
Can user enter the Location manually for a MODBUS device from DCE?
(CID:120134977)
Hi Yang Gao,
Unfortunately, Modbus devices do not have such a parameter: it simply does not exist.
Unfortunately this is not possible.
...But, nothing is impossible ;-).
Four years ago I found an uneasy, but reliable solution to this problem, i.e. in the DCE-server for Modbus devices, you can still specify SNMP-like parameters such as "vendor", "model", "type", "serial_num", "LOCATION", "CONTACT", "NOTES".
Solution: for each Modbus Slave-device, a separate and individual Modbus DDF-file is created, in which all the above parameters are written. In practice, this is quite easy, for example, if you have ten Modbus Slaves of the same model with an already working Modbus DDF-file, you need to create ten copies of this Modbus DDF-file. In each of the ten Modbus DDF-files, you must enter the correct location, contact, serial number and etc. of the Modbus Slave-device. Then, in the DCE-server, after importing of all ten Modbus DDF-files, perform discovering of each of the ten Modbus Slaves individually, choosing for each its corresponding Modbus DDF-file with the correct location, contact, serial number and etc. After that you will reach the set goal, i.e. in the alarm emails will be specified exactly Slave Location.
Here is my practical example of how it looks in the DCE-client for three Modbus Slave generating sets connected to the Modbus TCP/IP gateway (its IP and MAC addresses are also visible there). The screenshot clearly shows the location, model and contact of each of the three Modbus Slave generators:
(CID:120135003)
Posted: ‎2020-07-03 05:09 PM . Last Modified: ‎2023-10-22 02:43 AM
