Posted: 2020-07-03 04:38 AM . Last Modified: 2024-04-08 11:36 PM
Hi All,
In DCO when I generate the Inventory report by default only we can have the following fields or columns:
Name, Location, Barcode, Part Number & Description.
How can we have more columns added to this report? If we define the Custom properties or Template for a rack mounted device how can I have the complete information in the Inventory report as pdf format?
Please note the client is only having Operations, Capacity & Change license.
Thanks & Regards
Shemil
(CID:106891265)
Hi Shemil
All will require some coding and / report writing skills.
Cheers
Ed
(CID:106891353)
Hi Shemil
Cheers
Ed
(CID:106891353)
Posted: 2020-07-03 04:38 AM . Last Modified: 2023-10-31 11:09 PM
