Import network cables mapping to racks
  • Import network cables mapping to racks
129
112
72
Posted: ‎2020-07-04 09:14 PM . Last Modified: ‎2024-04-04 03:50 AM
1126
Hi
Suppose we have existing POD with some racks and configured equipment and power design/mapping, genomes, etc; How can I do excel import (that includes network mapping) to these racks without ruin the existing mapping?
I'm afraid all the configurations i've already made will be erased.
Thanks.
(CID:133367732)
  • Data Center Operation
  • Genome
1125
Hi!
There is no way to import only cabling via excel import.
Instead of excel import try to use ETL integration as described in ETL examples section: http://sxwhelpcenter.ecostruxureit.com/display/public/DCIMDEVELOPER/ETL+Integration+Examples
(CID:133367841)
Replies 5
1126
Hi!
(CID:133367841)
Hi
Thank you.
Suppose I do ETL Integration, does it erase the existing data?
(CID:133367934)
Posted: ‎2020-07-04 09:15 PM . Last Modified: ‎2024-04-04 03:50 AM
No will not delete/replace the existing assets. It can be used to add, update, and remove network connections.
Regards
Greg Sterling
(CID:133367950)
Thank you!
(CID:133367956)
Posted: ‎2020-07-04 09:15 PM . Last Modified: ‎2023-10-22 02:42 AM
