Import cabling
  • Import cabling
129
72
Posted: ‎2020-07-04 07:25 PM . Last Modified: ‎2024-04-04 11:13 PM
1396
Import cabling
I can not create a device with multiple network links.
When importing, I have the equipment but with only the first link.
File import : https://drive.google.com/open?id=1NvJOTYZArK9yUW7Hdczc8hpe6jeVjWF_
(CID:132656980)
  • Data Center Operation
Posted: ‎2020-07-04 07:26 PM . Last Modified: ‎2024-04-04 11:13 PM
1396
Hi!
Your file filled incorrectly. Your file describes only one connection. To add another one you need to create new columns with network properties - Network From Module Name 2, Network From Type 2 and so on for each network interfaces.
And then you need to move data from rows 3-10 to corresponding columns.
(CID:132656996)
Replies 4
1397
Hi!
(CID:132656996)
You are a genius 😂
It's done thanks for your help.
(CID:132659498)
You are welcome! 😀
(CID:132659496)
Posted: ‎2020-07-04 07:26 PM . Last Modified: ‎2023-10-22 02:42 AM
