Implications of 1 DCE integrated to 2 DCO servers.
  • EcoStruxure IT forum
  • Implications of 1 DCE integrated to 2 DCO servers.
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:23 PM . Last Modified: ‎2024-04-09 04:34 AM
537
I'm wonder what are the implications of configuring the same DCE server as an External System on 2 different DCO systems?  This would be required for DCE alarms and performance data to appear in both DCOs.
(CID:97485935)
  • Data Center Operation
539
Hi Ed,
The implication would only be the load on the DCE server as I see it. There are no data send from DCO to DCE which could mess things up. I would say that the DCE server performance is the main topic and therefore number of devices monitored, cameras etc are something to take into consideration.
I have had several DCOs connected to one enterprise DCE (only monitoring 100 devices) without any problems seen.
/Søren
(CID:97485943)
540
Hi Ed,
/Søren
(CID:97485943)
Posted: ‎2020-07-02 01:23 PM . Last Modified: ‎2024-04-09 04:33 AM
Thanks Soren
I've never really understood the function of the "callback" configuration setting in DCO when entering a DCE as an External System and was concerned there may be some type of conflict if 2 DCOs attempt to make some "Callback" setting on the one DCE
Best to test - and you're already doing
Cheers
(CID:97485954)
Posted: ‎2020-07-02 01:23 PM . Last Modified: ‎2023-10-31 11:08 PM
This is a heading
