ITA rest API token authentication
  • ITA rest API token authentication
129
72
www021
Crewman www021
Crewman
Posted: ‎2024-05-19 12:05 AM
1274
How can I generate token for ITA rest API authentication? How to use the token in API requests?
I tried using /authentication with username and password and generated a token. However, it showed Unauthorized when using this token in the following request. Are there any example how it should be used?
Thanks!
  • IT Advisor
Admiral
Posted: ‎2024-05-22 07:10 AM
Hi @www021,
I don't have much ITA RestAPI experience, but I was able to do some testing and get a token to work following the details listed in the "authentication: Authentication Service" "POST /authentication" section of the rest API documentation.
You can start by doing a call to get the token using the modelschema that contains the username and password:
When you click on the Try it out button you will receive a "token" within the response body.
You can use this token in the header field of other calls with the http header name of "Authorization" and the value being "bearer {insert_token_here}"
When you run an acceptable call, the call should execute and display results:
Kind Regards,
Cory
Admiral
Hi @www021,
Kind Regards,
Cory
thombrooks
Crewman thombrooks
Crewman
Posted: ‎2024-12-05 12:07 PM
Found out the hard way that the word 'bearer' CANNOT be capitalized (ie do not use 'Bearer') or it will fail.
