ITA Mass properties Change
  • ITA Mass properties Change
129
72
silvio.filho
Ensign silvio.filho
Ensign
Posted: ‎2022-06-15 04:54 AM
3047
Hello!
I`m searching a method to do a mass property change in ITA.
I had looked API Methods but see only the method to change custom properties from a device.
Can I do that changhes by ETL?
I Need to change power properties from a lot of devices.
  • IT Advisor
Replies 6
Captain
Posted: ‎2022-06-15 10:47 AM
3032
Silvio, which specific properties are you trying to change?
Regards
Greg Sterling
silvio.filho
Ensign silvio.filho
Ensign
Posted: ‎2022-06-17 07:14 AM
In response to gsterling
2949
I`m trying to change data like
Power
Tension
And another data in Power tab.
Captain
Posted: ‎2022-06-17 09:45 AM
In response to silvio.filho
2944
You can edit many properties from the desktop client equipment browser.
As an example below, I used the equipment browser to view an entire room of servers by opening the below room and filtering the equipment browser column "device type" and setting that to server.
Then select one or more of the entries in the list in the equipment browser, right click and choose to edit multiple items. From the below popup in the screenshot you can change many parameters including nameplate, adjusted nameplate, redundancy, input and output voltages as well as tags and custom property settings.
Note I also checked "edit all items in table" on the pop-up window so all items in the equipment browser would be changed not just the handful I selected.
Regards
Greg Sterling
silvio.filho
Ensign silvio.filho
Ensign
Posted: ‎2022-06-20 05:09 AM
2905
Hi Greg!
Thanks for your answer.
That method will help us a lot.
But, if I want to develop to my customer a custom solution, it is possible with ETL? Change that itens?
Captain
Posted: ‎2022-06-20 05:32 AM
2900
It is possible to change some attributes via ETL especially if you want to change custom properties, tags as well as the device name, bar code or serial number.
Some work is needed in advance to use ETL as the devices you want to manage in ITA need an association in place to its ETL record before you can change them.
REST api's can be used to change asset data as well, no associations are needed to use rest, but you will likely need to know the device UUID.
Regards
Greg Sterling
silvio.filho
Ensign silvio.filho
Ensign
Posted: ‎2022-06-20 07:04 AM
Hi Greg!
I Have tryied to do that changes using REST API but i Cant found anyone method to do this, then i will try using ETL.
Thanks for your Answer.
