IT Advisor 9.1.9 released
  • IT Advisor 9.1.9 released
127
65
JLehr
Sisko JLehr Sisko
Sisko
Posted: ‎2021-06-09 09:07 AM
1037
The IT Advisor 9.1.9 release includes:
Updates
  • Users are now able to model Multi-Fiber Push On (MPO) and Multi-Fiber Pull Off (MPO) fanout cables in the desktop client.
  • New genomes were released to the IT Advisor Genome Library. See Genome Library release notes
    Customers with a valid support contract can download the latest Genome Library here.
  • Various security fixes
Bug fixes
  • The network connection drop downs are now organized logically.
  • Other network port types are now counted throughout IT Advisor.
  • The online install now works as expected for version 9.1.0 and newer.
When you update ITA to version 9.1.9, the desktop client checks whether the certificate matches your domain name or IP address. Please issue a self-signed certificate.
You can find the ITA release notes, recent changes, improvements, and more in the EcoStruxure IT Help Center.
  • Data Center Operation
  • IT Advisor
Admiral
Posted: ‎2021-06-10 01:07 AM
There is a change in ITA 9.1.9 which could cause problems for the desktop client to successfully start.
When upgrading to 9.1.9 make sure that the 'SSL Certificate Common' name has the correct server IP defined. It can be verified via ITA server Webmin interface (https://<ITA server IP>:10000) EcoStruxure IT Advisor > Setup. Look for the field says SSL Certificate Common, this should correspond to the servers IP address.
If you need to change this value, then enter the server IP address and click the Setup button to confirm the change. Note: this will cause the services to restart.
This changes, if needed, can also be applied after the upgrade (to 9.1.9).
