Posted: 2020-07-04 06:11 PM . Last Modified: 2024-04-04 11:40 PM
Hi,,,
Please tell me how can we delete License key of nodes from StruxureWare central.
BR
(CID:131966077)
Posted: 2020-07-04 06:12 PM . Last Modified: 2024-04-04 11:40 PM
Dear Muhammad Shahzad,
As far as I know, unfortunately, the removal of license keys in DCE-7.x software is not provided (by the way, this can be another feature request for DCE-8.x, which you can easily create yourself).
Can you explain in more detail, why you need to remove license keys from a DCE-server?
For example, if you are going to transfer your DCE-server to a third party, then it's best to simply restore the DCE software from the iso-image (to get a web-link to download the restore iso-image you need call your local Technical Support). After this procedure, you will have a clean DCE-server with default license keys (only 25 device nodes + 1 surveillance node). I.e., this is what you need.
In addition, if you try to restore your DCE-server from a backup to another server (whether virtual or physical, no matter), but with other MAC addresses, then all your custom license keys will be removed (leaving only 25 device nodes + 1 surveillance node). It is also desirable to know.
With respect.
(CID:131966454)
With respect.
(CID:131966454)
Posted: 2020-07-04 06:12 PM . Last Modified: 2023-10-22 02:39 AM
