IBM Power9 and others
  • IBM Power9 and others
129
72
Posted: ‎2020-07-05 10:46 PM . Last Modified: ‎2024-04-03 12:21 AM
1600
Hello
2 things.
a) NO Genome update since May 2019....
b) I need a genome for an IBM Power9 L922 I can't pace the request
250
Tks a lot
Rocchino
(CID:149785498)
  • Data Center Operation
  • Genome
1600
Hi Rocchino,
Perhaps you might want to (as a workaround) customize your device by adding a similar item from Genome Library to your Genomes and then changing its name/properties that may fit your device.
Currently ddf/genome request can be posted in device support site: https://ddf.ecostruxureit.com
Kind regards
(CID:149785977)
Hello Jeff
Workaround already done....
DDF request done.
Can you tel why no update Genome update since May 2019??
Best regards
Rocchino
(CID:151060593)
Posted: ‎2020-07-05 10:46 PM . Last Modified: ‎2023-10-22 02:39 AM
