I need MAC-Address to my DCO running on Virtual Machine
  • I need MAC-Address to my DCO running on Virtual Machine
127
Posted: ‎2020-07-03 08:46 AM . Last Modified: ‎2024-04-08 03:45 AM
1119
Like many has asked, I need my DCO servers MAC adress in order to get licenses registered.
But, I'm running two DCO on Virtual Machines. Each is stored and running on its own physical HP-server.
I have access to the Webmin and downloaded the DCO Client 7.5 from them.
I've already went to "servername:10000" > System > Network Configuration > Network Interfaces > eth0 There, I'm not getting any MAC-addresses. It's blank on the hardware address. Is there any other way to get the MAC-Address?
Best Regards
Thanh Ly
(CID:110007271)
  • Data Center Operation
Posted: ‎2020-07-03 08:47 AM . Last Modified: ‎2024-04-08 03:45 AM
1119
Hi Ly,
You might want to try using the linux command, eg. ssh log in to the server and then type:
ifconfig
or
sudo ifconfig
the hardware address would be listed after "HWaddr",
I have masked my "MAC-address"/ HWaddr here:
Kind regards
(CID:110007278)
Replies 4
1120
Hi Ly,
ifconfig
or
sudo ifconfig
Kind regards
(CID:110007278)
Thanks for your help Jef! I was able to get the MAC-address/HWaddr. I'm trying to register it in dcimassets.schneider-electric.com. But when I choose SFDCOBASE, it's asking for Serial number. Is it the same as MAC-address/HWaddr ? I just want to make sure before entering my passcodes. Best regards Thanh Ly
(CID:110007290)
Hi! You can find Serial number in "About" window of DCO client.
(CID:110007303)
Posted: ‎2020-07-03 08:47 AM . Last Modified: ‎2023-10-22 02:38 AM
