I always get this alarm "An error occured [12030]" in DCE's webclient. Any resolution?
  • I always get this alarm "An error occured [12030]" in DCE's webclient. Any resolution?
129
72
Posted: ‎2020-07-03 05:36 AM . Last Modified: ‎2024-04-08 11:17 PM
972
(CID:108235243)
Replies 4
972
Hi Roel,
To access the StruxureWare Data Center Expert web client, you use a browser to launch to the IP address or hostname of the StruxureWare Data Center Expert server, and provide a valid username and password for that server.
Note:
To logon to the StruxureWare Data Center Expert web client, a user must have at least View Access for one device group that contains a minimum of one device.
BR,
Rana Ajmal
(CID:108235266)
Rana, I know. I am logged in (always) because we keep an eye on the equipment via this screen.
(CID:108824320)
Posted: ‎2020-07-03 05:37 AM . Last Modified: ‎2024-04-08 11:17 PM
Hi Roel, Is this a hardware or a virtual DCE? If its a hardware server,I would suggest you connect directly to the private LAN (default IP: 192.168.1.1 )and try and use the DCE web client there. If the issue does not happen there it might suggest that it is more and likely a network issue. Just for your review there is a KBase that outlines the ports that need to be open for client/server communication. FA158328, The link to the KBase is below: http://www.apc.com/us/en/faqs/index?page=content&id=FA158328 BR, Rana Ajmal
(CID:108824319)
Posted: ‎2020-07-03 05:37 AM . Last Modified: ‎2023-10-31 11:07 PM
