Humidity values in DCO cooling view
  • Humidity values in DCO cooling view
129
72
Posted: ‎2020-07-04 02:28 PM . Last Modified: ‎2024-04-05 02:37 AM
865
Hi team,
is there any option to view humidity values in DCO cooling view?
We have these values from DCE in RPDUs and also in cooling units and we would like to see this information over DCO.
Regards
(CID:128759945)
  • Data Center Operation
864
Hi Javier,
In Cooling overlay, the rack view would display the associated humidity sensor(s):
Web client will also display the sensor information:
Kind regards
(CID:128759968)
Replies 4
865
Hi Javier,
Kind regards
(CID:128759968)
Hi Jef,
I mean if it is possible to see the humidity values in the pop-up view in cooling tab:
(CID:128759995)
Hi Javier,
That is not supported, tool-tip dose not display humidity values.
Kind regards
(CID:128759998)
Posted: ‎2020-07-04 02:28 PM . Last Modified: ‎2023-10-22 02:36 AM
