Posted: 2020-07-02 03:37 PM . Last Modified: 2024-04-09 03:05 AM
Hello everybody
Do you know the procedure of upgrading a DCE v7.2.0 to V7.2.7? I don't find clear information about the procedure required.
I'm interested on migrate the data as well.
Thanks for your help.
(CID:102924868)
Angelica,
You can reach out to your local technical support team to receive upgrades for StruxureWare Data Center Expert. Technical support will need to verify software support before providing the upgrades.
http://www.apc.com/site/support/index.cfm/contact-information/
You can upgrade and keep your data for StruxureWare DCE 7.2.0 using the following upgrade path: 7.2.0 > 7.2.1 > 7.2.2 > 7.2.4 > 7.2.5 > 7.2.6 > 7.2.7.
Best Regards,
Cory
(CID:102924871)
Angelica,
Best Regards,
Cory
(CID:102924871)
Thanks Cory, I was needing to understand the required path to upgrade DCE. I'll contact support as well to continue this process. Thanks a lot!
(CID:102924887)
Posted: 2020-07-02 03:37 PM . Last Modified: 2023-10-31 11:07 PM
