How to set 1.5 u size generic path panel in Genome Library in DCO?
  • How to set 1.5 u size generic path panel in Genome Library in DCO?
126
65
Posted: ‎2020-07-02 10:49 PM . Last Modified: ‎2024-04-09 01:20 AM
975
I have a problem about DCO device placement.
We used 1.5 u sized patch-panel device. How to resize u of generic patch-panel by modiying generic patch panel model in Genome Library. Is it possible ? Thanks.
the patch panel having 1.5 u sized is Corning WAXWSV-04808-C002
Device attributes is;
http://catalog.corning.com/opcomm/en-GB/catalog/ProductDetails.aspx?pid=21772&vid=8765
(CID:105461548)
  • Data Center Operation
Posted: ‎2020-07-02 10:49 PM . Last Modified: ‎2024-04-09 01:19 AM
975
On behalf of Eduard:
Hi Umut,
You can use a workaround.
Change the mounting of your 1.5U patch panel to shelf and give it a height of 66mm (=1.5U).
Use a shelf (from the genomes) or an other device to put it on.
You can remove the shelf ones the patch panel is in place.
Eduard
(CID:105461625)
Replies 6
Hi Umut,
Currently in DCO the integer "unit height"/ U values are supported, ie. it is not possible/supported to configure the device U height to be 1.5.
Depending on the setup, I would suggest to configure the device "unit height" to be 1 U or 2 U (depending on how many patch panels you want to add right after each other).
Kind regards
(CID:105461562)
976
Hi Umut,
Eduard
(CID:105461625)
and if you change the Unit height to 0, it will not add up the U-heights used
(CID:105461735)
Thanks for answers, I place 1.5 sized patch panel by using shelf and editing height. But, If I place 2 patch panel 1.5 one after the other , This method is not worked because shelf is not placed in half u? Can Stine Verdelin Hansen help me with about this method ? Thanks; Thanks ;
(CID:105461823)
Hi umut.pilge, it was Everard Eduard who provided the workaround. Perhaps he can help? Otherwise you could try Jef's approach below and set the unit height to 2 on one panel and 1 on the next which will give a total of 3 U-heights used. Best, Stine
(CID:105461851)
Posted: ‎2020-07-02 10:50 PM . Last Modified: ‎2023-10-31 11:07 PM
