How to move from cluster setup to standalone + DR node
  • How to move from cluster setup to standalone + DR node
129
72
Posted: ‎2020-07-04 05:23 PM . Last Modified: ‎2024-04-04 11:56 PM
812
If you are currently running on clustered environment and would like to "move" the setup to standalone + disaster recovery (DR) node, here is how to:
  1. Backup the current solution
  2. Make a clean installation of two standalone servers: one to be used as operational server and  the other one to be used/configured as DR node.
  3. Backup file (from  step 1/cluster setup) can now be restored on the operational server, which you have setup in step 2.
  Note: The high availability license included in your backup file, is also valid for the new setup (standalone + DR).
related tip: How to: Configuring Disaster Recovery, step by step
(CID:131336771)
  • Data Center Operation
Thanks for sharing Jef Faridi!
(CID:131961314)
Posted: ‎2020-07-04 05:23 PM . Last Modified: ‎2023-10-22 02:33 AM
