Posted: 2020-07-02 10:47 PM . Last Modified: 2024-04-09 01:20 AM
Hi Team,
I am modeling a rack ATS (AP7724) but I can't see the power option to model Feed A and B, also I need to connect the single corded load on the ATS.
Any suggestions?
Felix.
(CID:105461477)
Hi Mashwiz
Power connections to Rack ATS's is not currently supported. You will be able to add them to the rack, but you can not add power connections to them. Only floor mounted ATS's are supported.
Jesper
(CID:105461480)
Hi Mashwiz
Jesper
(CID:105461480)
hi Mashwiz Also to add to Jespers comment, floor mounted ATS's cannot be adapted to be mounted in a rack. What we have done for a few customers is as follows; - Created a shelf - called the ATS name - Mounted a half size shelf mounted devices (rPDU) and connected to power source A - The same again for power source B I know this is not clean but it does show two power streams connected to the device in the power dependance view
(CID:105461775)
Posted: 2020-07-02 10:48 PM . Last Modified: 2024-04-09 01:20 AM
Hi guys, Thank you. Regards, Felix
(CID:105461779)
Posted: 2020-07-02 10:48 PM . Last Modified: 2023-10-31 11:06 PM
