84344members
353523posts
How to migrate devices from snmpv1 to snmpv3 and http to https
Csilva
449
I wish to change the communication protocol of DCE, for the devices discovered into DCE from Port 80 to Port 443 and move from SNMP v1 to SNMP v3. I wish to know if this can be done seamlessly without loosing any sensor history for Devices UPSs. Tenemos las siguientes marcas: (Liebert, General Electric, Forza, ABB, Toshiba)
Saludos
Caroll
2 Replies 2
MateFekete
Re: How to migrate devices from snmpv1 to snmpv3 and http to https
I was in the same boot couple of years before and I used the following great article to change from SNMPv1 to v3:
https://www.apc.com/us/en/faqs/FA158442/
To be honest I don't remember that historical data kept or not. I suggest to you just test it first with one device and you'll see.
The http > https should not be impact the monitoring and historical data (unless it is a NetBotz). The batch change can happen in the same way like for SNMP on APC devices. On 3rd party devices it need to be changed manually.
Sanchez_79
If an organization has 1000 of devices then to check all devices, one by one every day, are working properly or not is a hectic task. To ease these up, Simple Network Management Protocol (SNMP) is used.
skylight paycards
