How to export all of device from DCO to csv?
  • How to export all of device from DCO to csv?
129
72
Posted: ‎2020-07-03 03:23 AM . Last Modified: ‎2024-04-08 11:59 PM
1023
I would like export export "everything" from DCO to csv. I know that in the section of "Equipment Browser" find the "Export Table" icon.
In that window there are two check box option:
"all equipment, including filtered out equipment."
"all columns, including hidden columns."
If I check the first one it will export only that devices which are in the opened rooms.
My goal is to export all devices from all room.
How can I do that?
(CID:106205934)
  • Data Center Operation
1022
As you found out, the equipment browser works on the room level. If you want to perform more extensive import or export operations, you should consider using ETL: External System Integration Through ETL
(CID:106205963)
Replies 4
1023
(CID:106205963)
Thanks Martin. Is there any wildcard character when I search in equipment browser? Like * or %, etc...
(CID:106206163)
You cannot use wildcards but you can use some basic filtering rules (including "As you type, the table shows all items that contain the typed characters"). See Filtering and finding equipment in Equipment Browser for more information.
(CID:106206164)
Posted: ‎2020-07-03 03:23 AM . Last Modified: ‎2023-10-31 11:05 PM
