Posted: 2020-07-04 12:12 AM . Last Modified: 2024-04-05 04:40 AM
I want to delete the old ITO server,
The main reason is that the server network environment has changed.
But when I tried to delete the ITO server, I was unable to save it because of the reason for the license (more than the number of cabinets).
Is there any solution? Thank you
(CID:126159451)
Hi guanyc,
DCO will not allow user to save any changes when the number of rack modeled is higher than the DCO rack license qty.
Please check the number of racks you have and the license available.
For DCO 8.X you can see the licensed consumed from the web client-->Administration-->Licenses
From there you will be able to see how many racks exceeding the license that you need to delete before you can save any changes in DCO.
Chris
(CID:126159461)
Posted: 2020-07-04 12:12 AM . Last Modified: 2023-10-22 02:29 AM
