How to connect to power monitor device satec bfm136?
  • How to connect to power monitor device satec bfm136?
129
72
Posted: ‎2020-07-06 12:45 AM . Last Modified: ‎2024-04-02 11:27 PM
2468
HI,
I would like to connect to a power monitoring devise such as SATEC in order to have the 3 phase details and the total power consumption.
thanks
(CID:153552467)
  • Genome
Replies 4
Dear sheep,
Please, specify if your question is about DCE or DCO?
Probably you need the appropriate DDF-file, not the genome, as you indicated in the tag of this question?
With respect.
(CID:153552471)
Thanks for your response,
Yes, we would like to connect our DCE to a monitoring device (energy monitor).
The device communicate with modbus protocol.
We also have DCO module if needed.
 Attache link to s similar device :
https://www.slideserve.com/kyria/bfm136-branch-feeder-monitor
Kind Regards
(CID:153554579)
Dear sheep,
You need to download the Modbus DDF-file you need from DDF web-resource as below:
Then you need to import this Modbus DDF-file into DCE software and check it with your device.
I hope this is what you need.
With respect.
(CID:153944160)
Posted: ‎2020-07-06 12:45 AM . Last Modified: ‎2023-10-22 02:28 AM
