How to configure and control ETL Schedule Frequency
  • How to configure and control ETL Schedule Frequency
129
72
wesburhoe
Ensign wesburhoe
Ensign
Posted: ‎2022-02-11 12:23 PM
1047
Good day all!
A bit of background first... as most know, ITA offers an ETL process for exposing modeled data via PostgreSQL DB's. When setting up an ETL job, there's options for setting the "Schedule Frequency" to be an interval. The available option is to set an interval by minute or hours.
This is great, and working well for us... but have run into an issue. Say you have an export DB and and import DB configured on a 3 hour interval. For us, we want to make sure the export job runs first... followed by the import job. Reason for this, we process data outside of ITA using the export... which then feeds into our import job.
The question is : Is it possible to manipulate when these 3 hour intervals fire... without having to destroy the ETL configuration, etc. Last I heard... to only way to kick these job into gear in the proper order... it's about when you CREATED the ETL job originally.
Thanks!
  • IT Advisor
Captain
Posted: ‎2022-02-14 10:35 AM
Hello Wes, We will check into this in more detail.
My first instinct is to wonder whether this could be done in a "batch" mode where you turn both off from a schedule standpoint, use an external entity to enable the import job and run it "immediately", then wait for that job to complete, then enable and run the export job.
Then turn both off.
Perhaps dev will have a better idea about making the jobs more "dependant" on each other.
GregS
