Posted: 2020-07-04 07:35 PM . Last Modified: 2024-04-04 11:10 PM
I want for every piece of equipment to be able to add serial number and tag number.
I see that under general we could add serial number for each equipment but I want to add a tag number (is how we track our assets) and also to have the ability to export this information when requested. What's the best way to do this? Can it be done?
(CID:132657724)
Hi Rose!
YOu can add tag number to Barcode field under General tab.
This field should be unique within your DCO solution and this info is available in Equipment Browser and Inventory report.
(CID:132657747)
Hi Rose!
(CID:132657747)
Thank You for the quick response. I added serial number and used barcode for my asset number however when I run a report only barcode populates.
(CID:132657752)
You have two options:
(CID:132657773)
Posted: 2020-07-04 07:35 PM . Last Modified: 2023-10-22 02:25 AM
