How much time cost upgrade DCO 8.2
  • How much time cost upgrade DCO 8.2
126
65
Posted: ‎2020-07-04 02:30 AM . Last Modified: ‎2024-04-05 03:48 AM
775
I was ungrading to DCO 8.2 from 8.1 but the process stop after 30 minutes in
Nov 28 20:00:15 xxxxxx operations-upgrade[37024]: Updating : e2fsprogs-1.42.9-10.el7.x86_64 241/524
Can the update still be running?
How long is the update process?
(CID:126182100)
  • Data Center Operation
775
Hello Miguel. What specifically happened to make you think the upgrade stopped?
It is possible the upgrade is still running. The time it takes for an upgrade to complete depends on several variables including the performance of the DCO server and the size of the solution being upgraded so we cannot predict a specific amount of time.
From the webmin interface if you click the "status" entry under "StruxureWare DC Operation" ... if its still upgrading I think it will report the server is being upgraded, if the status shows everything is running then check the "about" entry in that menu to see if you're now running DCO 8.2.
Greg Sterling
(CID:126182295)
776
Greg Sterling
(CID:126182295)
Posted: ‎2020-07-04 02:31 AM . Last Modified: ‎2024-04-05 03:48 AM
Is running fine, after 1 hour the procces continue
(CID:126183954)
Posted: ‎2020-07-04 02:31 AM . Last Modified: ‎2023-10-22 02:24 AM
